Hauptständer für die Clubbi 20 Aug 2012 13:31 #51351
TIPP: Wer für seine Clubman nen Hauptständer sucht sollte sich mal die letzten beiden Bilder von unserem dänischen Kollegen anschau´n:
www.motobornholm.dk/honda_gb_500.html
Schöne Grüße,
Anja
Re: Hauptständer für die Clubbi 20 Aug 2012 21:15 #51354
Hallo Anja,
die Fotos habe ich schon bewundert, sieht gut aus!
Auf der HP unserer niederländischen Freunde gibt es in der blauen Leiste unter Techniek (dann ganz runterscrollen!) eine noch bessere Anleitung unter Verwendung eines XBR Hauptständers, ganz ohne Schweißarbeiten am Rahmen! Die Laschen werden nur geschraubt, finde ich super, werde ich mal im Winter machen!
Gruß Kurt
Re: Hauptständer für die Clubbi 21 Aug 2012 11:09 #51360
Hallo Anja & Kurt,
Sorry for writing in English, my writing in German is no good - hope it's OK.
Thanks for your comments.
The nederländische projekt looks very good, and it's smart and simple, however with the GB standard exhaust, it will never work. There simply isn't room enough for the exhaust silencer.
Also the 20 mm shaft will never fit into the shaft bushing of the standard XBR 500 haupständer, which is probably only capable of a 8 or 10 mm shaft.
But, if you modify the exhaust, and place it on the right side of the engine, like the XBR 500 standard exhaust, then you have plenty of room for the 20 mm shaft. Consequently you'll also have to make a new bushing, which will fit the 20 mm shaft. Furthermore, the spring connecting point must be placed somewhere on the shaft, and also the stopping of the haupständer, when standing and up, must be fixed. It's not that easy hm...
I've studied the standard haupständer on a XBR 500, recently, and it looks quite complex.
My construction took me 3-4 weeks from idea to finish. It works well, but since I'm planning to make a new exhaust - connecting the 2 pipes in front in one pipe,and then have the one pipe to be moved to the right side of the engine, finally connected with a Velocette Thruxton silencer for a better sound - I might as well implement the nederländishe idea / system, which is far more simple than my present haupständer - but it'll need various modifications, in order to work.
Re: Hauptständer für die Clubbi 21 Aug 2012 23:02 #51374
I have registered on the Dutch club web site, and contacted Rinus, the maker of the XBR 500 centerstand on the GB 500, and asked for more pictures and information.
Will let you know, when I have.
Re: Hauptständer für die Clubbi 30 Aug 2012 20:47 #51454
servus anja, erik, kurt,
das ständerli macht mir einen guten eindruck.
hab's aber bisher nicht geschafft, mit dem konstrukteur zu kontakten.
kann mir einer weiter helfen?
danke für die mühe
ciao doschaugher
Re: Hauptständer für die Clubbi 30 Aug 2012 22:46 #51456
Contact me by e-mail: Diese E-Mail-Adresse ist vor Spambots geschützt! Zur Anzeige muss JavaScript eingeschaltet sein! and I'll send you the pictures I have, and give you the e-mail adr. of the constructor.
OK?
Re: Hauptständer für die Clubbi 31 Aug 2012 22:06 #51478
ja da siht man mal was für eine Arbeit so ein Hauptständer machen kann
Ladezeit der Seite: 0.322 Sekunden
