New brake pads not working?
- olof
16 Dez. 2009 17:37 #39577
von olof
New brake pads not working? wurde erstellt von olof
Hello!
I'd like to thank you guys that helped me when I had carburator problems. After buying the kit from mainjet.de it works good now, and I was also finally able to reach the spark plug
But ofcourse, nothing good cannot come with some bad. I bought new brake pads at wemoto.co.uk
www.wemoto.com/bikes/Honda/XBR_500_F_G/8...BC_Standard_GG_Type/
But after mounting them, the wheel locks up! I tried several times, but the pad on the non piston side kept grabbing the wheel and this was before I had even pressed the hand brake to start pushing in the pistons. What could be the reason for this?
Its driving me mad!
Its driving me mad!
16 Dez. 2009 19:05 #39578
Harri antwortete auf Re: New brake pads not working?
Look for part 11 and part 13
They are very often rusty and doesn't move in the caliper.
Sometimes it is done, if you clean both and put new grease on it.
But the best possibility is to buy a new part 11, (Honda nr 45111MA3006)
(Normaly you need for changing also 2 x part 15 (Honda nr 45133166016), and 1 x part 14 (Honda nr 45133MA3006) cause this parts are often shredded.)
If you don't get this parts from your local Honda Dealer, you can order all parts from Mainjet ( Part 15 Mainjet / Part 11 Mainjet )
- Harald_aus_den_Bergen
17 Dez. 2009 09:08 #39579
von Harald_aus_den_Bergen
Harald_aus_den_Bergen antwortete auf Re: New brake pads not working?
Auf Harri ist einfach Verlaß!
Und so schön mit Verweis auf die Explosionszeichnung hätt ich das wohl nicht gemacht. Bravo!
Schöne Weihnachen schon mal für alle, dies brauchen können.
- olof
19 Dez. 2009 18:13 #39584
von olof
olof antwortete auf Re: New brake pads not working?
Hello!
Those parts look like they're in good condition, but I think I need to open up.
Anyone know where to finding a guide about rebuilding the caliper?
There is supposed to be on here in www.xbr.de .
19 Dez. 2009 18:28 #39585
choice antwortete auf Re: New brake pads not working?
It is here:http://www.dolecek.de/xbrat/bremse.htm
Unfortunately in German.
Ladezeit der Seite: 0.410 Sekunden
